426D in a D17
VicS
Location
SE Il.
Will try to post a picture. Almost ready to take to a pull.
Just cut the combine flywheel to size. Then used a Ford diesel clutch.96. Then laid combine plate on D17 plate and drilled new holes in combine plate. Then cut to size. Starter is from a 180. Lot of grinding to get it to work. Oh I had everything balanced. Believe it or not pressure plate was out of balance the most.
I have not left anything on it it doesn't
need to turn to the right. Hoping for 4000
with 18.4x34. Will let you know. Above I
said I used the original engine plate. But
I used a plate from a 180.
