Sherwood Botsford
New User
Running fine, 20 minutes before. Stopped, got off, got some of my people working again. Won't start.
* In postion 3 (normal run postion) gauges work, signals work, lights work.
* In postion 4 (spring loaded starter postions) dead silence. No clunk, no groan.
* Battery reads 12.61 V.
I suspect an interlock issue, but the only one I know is the clutch interlock. Checked that with volt meter. No problem.
At this stage I think it is one of:
* Interlock.
* Starter switch.
* Starter Relay.
* Starter motor.
The motor seems to be a poor choice, as if that were the problem, I would expect to hear at least the starter relay click.
Questions:
A: Are there other interlocks besides the clutch?
B: How do you check anything behind the dash? Rmoving the 8 screws allows you to move it about half an inch.
C: Other ideas as to what to check?
