20 - 35 serial number
resden
Where do I find the serial number on an ALLIS 20 -35? Am helping a neighbor liquidate his inventory of 80 Allis tractors and want to confirm that his is a 20-35!
It is on rear axle of tractor. I think it is either just left of the shifter or underneath the seat base. I am not near mine to give you the exact location.
TractorData.com - information on all makes and models of tractors
When the Allis-Chalmers E 18-30 was re-tested in 1921 at 930 RPM, it produced a rated 38 belt horsepower. The tractor was re-named the 20-35.
Dimensions & Tires:
Weight: 6640 lbs [3011 kg]
Front tire: 36x6
Rear tire: 50x12
20-35 Serial Numbers:
Location: Serial number on a plate in front of the steering wheel until 1927. After, the serial number is front of shifter on transmission case.
1923: 6161
1924: 6397
1925: 6755
1926: 7369
1927: 8070
1928: 9870
1929: 16762
1930: 23252
Final: 24185
Allis Chalmers 20-35 Power:
Drawbar (claimed): 20 hp [14.9 kW]
Belt (claimed): 35 hp [26.1 kW]
Drawbar (tested): 33.20 hp [24.8 kW]
Belt (tested): 44.29 hp [33.0 kW]
