Am-2795-10 wheel weights
Dustyah
I have 4 wheel weights am-2795-10 that I was going to put on my wd-45, curious to what they weigh, will they help with my traction problem, :?
I don't know the casting number on my OEM WD weights. They are about 130#.
Are your tires loaded? WD45 needs probably 1000# ballast to get it where it needs to be. Do you have 14.9x28 tires? Some WD45's had 13.6x28.
14.9-26 gleaner wheels, got some 13.6-28 spin outs that I plan to use with weights, with calcium, how much does fluid add to a 13.6-28
Do your rear wheel weights look like these? If they do they weigh 140lbs. each. This tractor has 14.9-28s on it
