I removed the governor cover and the governor unit inside so I could access the bottom bolt on the water pump when I replaced it. I didn't realize it mattered as to where the governor unit was installed when I put it back together so I stuck it back in and now the tractor won't start. I guess it could be coincidental and something else wrong but someone told me I probably got it out of time. If so, can you please help me step by step to get it fixed? I haven't Re-installed the radiator yet so it won't be hard to open it back up if needed. I did put the #1 cyl (closest to radiator) at TDC on compression and the rotor pointed between #1 and the next going clockwise.
Please help
Please help
