Type of Oil for AC D-10
acjim
New User
Hi, anybody know on a D 10 what kind and weight of oil does it use for the transmission? Does the transmission, rear end and hydraulics all use the same oil, and where is it added? Thanks!
I had a D 14 and it did not used the same oil in transmission, hydraulic lift system and the wheel bull gears,
Always good advice, get a manual, be sure, follow the manual, you can do some serious damage to mechanical equipment using the wrong
lubricants
Free advice is sometimes worth what you pay for it,
Oil for transmission and hydraulics is all the same. I use universal hydraulic/transmission fluid. This is basically 20 weight
non-detergent oil.
