AllisD17-1
New User
We have an Allis D17, serial #12249.
The governor was running wide open, so my husband took the tractor apart and discovered that the governor gear and at least one of the weights were broken. I found the parts online and all but the governor gear are in. My husband has everything cleaned up and ready to put the tractor back together once the gear arrives.
However, he can't figure out how to get the distributor timed, because the cam gear only has a timing mark on the crank gear side. There is no timing mark on the governor side on the cam gear.
Can someone please help us?
Thank you...
Thank you...
