bwillett
- Location
- West Central Ohio
I need to replace the front support and block assembly on my 1936 Unstyled WC with standard dual front wheels. Will any front support for a WC fit and work???
My tractor is a hand crank start and it is the one piece crank. The crank goes in the support right in the middle over the steering spindle...
It has steel wheels cutoff for rubber tires. They are spindle mount, no hub with lug studs....
