Toms trucking
New User
We installed a new head gasket on the d motor grader with a 262 conversion the head and deck looked pretty good we found a stripped head bolt so we heli coiled the hole and put all new bolts in they all torqued to115lbs so far so good. we had to pull start it to get it to fire it seems to purr 50 lbs oil pressure cold 20 lbs warm hope that's good I had the starter rebuilt and rewired everything but the starter was binding someone put the wrong bendix a 13 tooth we installed a 10 tooth and now it starts beautiful every thing seems to work. hydraulics, transmission, brakes, clutch seems a little stiff. Can anyone tell me is there a way to adjust the drive chains one on each side is very tight and the other very loose. I'm also looking for some parts fuel tank,steering box so far . Any help or info would be appreciated. thanks
