Allis 5050 Turf Tires?
Sandon
New User
Have an older Allis 5050 2wd with bad rears (14.9-28) that need replacing. Has anyone put turfs on a 5050 and what size did you go with? Any good source for used tires?
Not familiar with fit between models. Also, live MN so possibility depends on distance between.
Definitely too far but the wheels off your tractor will interchange with all the smaller Fiat built 3 and 4 cylinders like AC 5050,5045,5040.Long 445,460,560,Oliver 1265,1365 and some others.
Your tractor is about the same tractor as the Long 460 and the Oliver 1265.
Looks like they used a 14.9x28 tire. Shouldn't be real hard to find. Maybe check with a combine salvage yard. They used a lot of those as steer tires. Even a 13.6 would work but it'd be a bit lower in the rear.
AaronSEIA
