8050 vs 8070
Im trying to find out what the differences between an AC 8050 and 8070 are besides the PTO shafts, are they the same size wise? I was told they have the same engine with the 8070 just being turned up more. Any suggestions or information would be helpful. Thanks
You weren't told correctly. The engines are identical except for the crankshaft, crank pulley/dampener and fuel pump settings. 170 HP versus 154 HP. If it is an FWA tractor, the complete driveline is identical between them. If the 8070 is a 2WD, the rear end final drives are different. The 8050 had a 540/1000 PTO and the 8070 had a big 1000 PTO.
