Wd45 hydraulic pump
Dale c mi
The hydraulic pump drawbar control has a bad oil leak. Took it off, went to agco
for parts. Bushing takes 4 @$49.99 each, seals takes 2@$19.80 each plus
gaskets at $8.50 and shaft asy.. Regulating arm-That they can't get. Soo need to
know if a pump from a wd is the same as the wd45 pump. Thanks Dale
Should be. Take a look at the parts book at www.agcopartsbooks.com. Log in as a guest and search for WD.
AaronSEIA
AGCO used to sell a rebuild kit that was very complete and was much cheaper than the sum of individual parts. Would not have the lever though.
