Before you think about rebuilding it, what exactly is the problem, and how long have you owned the tractor ??
I have owned it 10 years. Always been slow on the 3 pt. Will not lift without rpm's high. Now pto out. I just wonder if I can turn the pressure up or need rebuild.
Having to throttle the engine up above 1500 to 1700 RPM or so to get the hitch to lift is very NORMAL for that hydraulic pump. Not saying fresh seals inside might not improve it some, but that's the way they are. "PTO out" isn't very clear, as to what the issue is there. Two different hydraulic circuits altogether. All lift functions are on the high pressure circuit and the power steering, PTO and Power Director clutch are on another circuit.
