DLM
Are the final drives the same on model B & C ? i need a Pinon shaft & bull gear for a B final drive. thanks Don
I think they are but do not know 100% sure. I know the axles and housing on the C are longer/wider then the B
The axle or pinion shaft is different. There was at least three final drive ratios used in the Bs. The C ratio being the slowest thus you need to count teeth to confirm before you mix and match.
