180 pto issues
Have 2 180 diesels the running 180 is serial number 11917,and my parts 180 is 2256 I took the pto assembly and gear out of the parts tractor and installed it into the running one. I went to bale and it sure seems the pto runs slower than the other tractors I have its hook up good and strong just spins slow.. I know their was a serial number brake at around 6000 and some for pto parts. Iam not sure what I missed to get the pto to run faster.thanks steve
Need to be more specific on exactly what parts you swapped. If you removed the PTO clutch box assembly from one tractor and it's driving gear above it, you must have transferred a 540 RPM clutch set-up into a tractor that has 540/1000 PTO. That is what you get.....a 1/2 speed PTO.
Yes I changed the pto clutch assembly, housing and driven gear from one to the other. So now I need to change gearing in the back to make it only 540. I didn't touch anything else beside those two things. I really like this tractor. What do I need to remove to switch gearing?Assume in the rear of tractor now. Thank you.
To make it work correctly, you need to replace the whole lift arm housing assembly and the PTO output shaft.
I was affaid of that I didn't get any of the 3 pt housings at all. Guess I have to search for the drum from the org unit. The pto clutch drum broke a piece out and all the discs are shot. Know of any rebuilt units for the upper serial number?
