Allyn in OK
I'm fixing the D15 to sell and found gear chips in the rear end. The differential ring gear looks good but the pinion is bad. Questions I have are, first, what else should I look for that may have caused the problem? The pinion bearings seem ok and don't feel loose. Second, what other models use these gears? I searched these archives and didn't find an answer but another forum response indicated that CA gears would fit a D15. Does the Series II use the same ratio as the earlier D15? These Series II gears are 6 and 37 tooth. Finally, where is the best place to get replacement gears? Sorry about the duplicate picture.
