Model C allis chalmers
teddy52food
Looking for the head bolt torque and valve tappet clearance. I tried on the left but the website declines to show the page. I don't know why. It used to work but not now when I need it. Thanks.
Head bolts torque spec is 60 ft. pounds. That is in clean lubed holes with lube under the bolt head. Rocker clearance has .010 called out on both intake or exhaust but I use a snug .012 on both.
Glad I checked. All the bolts were a little loose & some tappets were too loose & some too tight. Thanks again.
