Had broken the point on the B plow I have and have found and replaced it with another new unused one. I went to the field to complete plowing and set the plow in the same set up I used before the point broke. The plow cuts in the ground real good. To goo for the tractor. It bogs down and then I get wheel spin, have to stop and back up and start again. This clearly wasn't the case with the old plow point. I have adjusted the front lift arm up to hole three from the end and as well adjusted the handle to be as far up as possible. It should lift the plow some out of the ground so it's not so deep but I am still not seeing results that work. Maybe someone has gone through this issue and can help solve this problem. I've posted in the equipment section on Allis Forum as well the same message so you may see it both places if you look.
