I finally got to taking apart the steering box on the model D road grader I?m working on. Matt in PA was kind enough to offer me a power
steering unit for this machine but the problem is that the system still uses the original box which is all but shot. Looks like there
were needle bearings in the roller that disintegrated and fell down into the sector bushings and chewed everything up. Some of you have
said that you converted a GM (Saginaw) power box to fit (which seems like a much more economical fix). My question is; Can those that did
share some pictures of their conversion? Also; did you splice it into the grader?s hydraulic pump or add on a separate pump? Thanks in
advance.
advance.
