226 governour service?
R&W
i am rebuilding a d-17 engine, someone mentioned in a previous post that the governor needs to be serviced on these engines. what exactly needs to be done to them? mine shows now visible defects or major wear, is it ok to use?
New governor weights, pins and clips. The hole in the weights on the arm side will get loose and then the weight breaks off and falls thru the timing gears.
