AC WD-45 Flywheel timing mark question
NormanO
New User
How do you identify the flywheel timing mark to set the timing on a WD-45 when viewed through the inspection port?
If you have the I-T manual AC-11 paragraph 140A explains it very well. If you do not have it you should get one it will help you a lot. It says to line up the FIRE mark on the flywheel. If you need more help send me an e-mail and I'll scan that page for you
Get the #1 cylinder up on TDC on the compression stroke then mark the F that it is on and then see where the other one sits.
