WD45 Seat Shock Spring
when I painted my WD 3 yrs I took the seat shock apart and painted the shock (oragne), spring (silver) and end plates (black)
the one on mine had been replaced a cpl yrs before I got it per the info I got from the PO and it looked pretty new compared to everything else around it
you can see it in the photos painted
not sure if you can buy just the shock or not
but if yours is collapsed the spring is probably done as well
I would replace the whole unit with a new one
YT sells replacements see link
wd seat shock/spring assembly
The WD and WD45 take a different shock spring set up. The second photo is a better shot of a WD45 shock spring set up. Its completely new and run about $100.00.
