error code in 9655 agco allis
RVS
i have an Allis 9655 that shows the error code 46 and will not mnove .The tractor has been sitting since last fall in a shed and has been started once a month all winter. Went to take the tractor out and it would not move. The error code 46 comes up. had the tractor floated to another location.Started the tractor and it moved fine, lots of power no slippage. Stopped the tractor and it would not move again. same code appeared.Any suggestions
Found this using "Google" 7740 ford with E46 code
Chester I have a 1997 7740 ford sle showing an error code e46 does anyone know what this means it has stopped moving. thanks
Randy I have a 94 7740 and it came up with this code and would stop moving. I called the dealer and they could not find this code in the book and they where going to call the factory but never called back. I changed all the hydralic filters and that has seemed to help so far.
A.J. Kielian we have a 6640 with E 46 code it stop moving. we changed all hydr. filters and the code will not clear.
Harvey I have a 6640 with a code e24 it won't move until clutch is released to the top then it jumps. What causes this?
michael e46 is usually a follow uo to a blown fuse something to witht he gearbox. i drove a 8340 sle and it brought up e46 but it goes away when the fuse is replaced, i dont know what the fuse is but this problem happened after the e41 code came up
t e46 on the 7740 is #12 fuse blown dont know if it is the same might look
t the #12 fuse is located in the bottom left corner of your fuse box on the right hand side of steering box in the cab. hope this will help
Thanks ,i will try the filter first it pribaly needs to be chnaged anyways. Will let you know what happpens
