Stephen957
New User
This message is a reply to an archived post by Stephen957 on May 15, 2015 at 19:31:36.
The original subject was "1959 D14 project".
I bolted a new stainless battery tray on today. She started up today, thanks to a new batter, yet, ran a bit rough. I removed the oil bath air cleaner and soaked in a five gallon bucket full of gasoline after cleaning out two inches of mud in the oil cup. The sediment bowl was removed & cleaned. The gasket leaks. A new gasket and filter is on the way. I discovered the alternator bracket was broken and the fan belt is worn. Both replacement parts ordered via Yesterdays Tractors. Thanks to a tip from the forum, I sprayed the rusted bolts & nuts for the muffler, put a 9/16 socket & breaker bar held down with binder twine on a cement block. Hopefully, the nuts will break loose soon. Otherwise, I'll try using some heat from a butane torch to break them free.
Springtime in the Northern woods, when young men's hearts turn to love and old men like me return to tinkering on our old tractors.
