Battery removal on model B and rear rim / tire
Jlpb61
I have just acquired a 1941 B. Needs a lot of work plus rear rims and tires9.5/9-24.
Is there an easy way to change out the battery? I would have thought the box would have a side that came off.
Also where is best place to find rear rims and tires?
top comes off the battery box, then one side comes off... if yours is a box, it is not original..... new rims can be found from vendors..... used on E-bay.
Any local farm tire supplier can get both tires and rims. I put quite a few of them on B's and C's among others.
(quoted from post at 20:05:30 04/21/16) Any local farm tire supplier can get both tires and rims. I put quite a few of them on B's and C's among others.
Thanks guys mine is a box. No sides come off
Take the top of the box off. Disconnect the battery cables. Take the bolts out of the bottom of the box and remove box and battery together. Then the battery will come out. Call Tucker Tire in Dyersburg TN for your tires and wheels.
Tucker Tire
