Mathias NY
2 years ago I parked my Allis B in the barn and let it sit. Yesterday I decided to get it going again.
I changed the oil. It had some water in it, but that's not surprising because it sat outside before it went into the barn. I checked the coolant level, that was still fine. I added some fresh gas and after fixing a sticky float in the carb, it fired right up.
I let it warm up for about 10 minutes before it over heated. To my surprise the radiator was empty and the crank case was over full. The tractor only has about 10 hours on a new head gasket, but it did look wet around the #1 cylinder. Prior to this I had not noticed any coolant leakage.
Is it common for a head gasket to fail like this or it is more likely something else like a sleeve liner seal?
Thanks for the help!
