Lumbersawyer,
Rather than pull a wheel off in this cold of weather, I think maybe I have come up with an
easier way to get the same measurements. I now have the rear measurements and the axle
opening height and width. What I need is the front where it angles up.
So what if you measure from the rear lower sheet metal next to the rib, up over the top, to
where it stops at the front angle iron piece. Then measure the top back to where the angle
starts along the bottom, right behind where the belt pulley is, this can be done from the
wheel side. Would that be easier?
