WD 45 serial number
There are two humps on top of rear axle ( brake covers). Just below left hump is a hole ( seen in picture) and under it you should find serial number. It my be hard to see if tractor has been repainted several times.
There is a very slight possibility that you don't have a S/N. The reasons would be if the entire diff housing was replaced,and S/N was not re-stamped (not likely) and second if there was a dealer to dealer swap they didn't want AC to find out about the S/N could have been ground off. If it was ground off the area will show grinder marks. Most likely you aren't looking in the right place or that area has heavy paint on it.
Note the area that is white that is where the serial number should be if it is there at all
just below the hole into the left brake housing
if you're standing at the back of the tractor
it's just to the right of the top bolt for the lift arm brackets on the left side
it's the little silver box you can see in the pic of mine
most likely you'll have to scrap and wire brush the paint there to see it
Blue water Massey! Could you tell me where to get a seat like that, for my 2 WD45's. I choose comfort, over correctness! E Mail is open
seat came from TSC Ralphwd45
it's a universal fit one 50 bucks bought it for my riding mower
since the original seat was badly split I used that one till I found a good original one
that was the only pic I had of the back to show the ser #
I found I sat to high with it but did like the back rest
