mikes54jubilee
I just restored my 1964 D19 diesel , (only had it for a year)just wondering the right way to bleed the fuel filters. I see there is a plug on the bottom of the first one (I assume you open that one first) and two plugs on top. A plug on top closest to the pump and towards the other end. I guess you take one of those out to bleed the filter next to the pump? Also my tractor has an GM alternator. I wasn't sure about wiring the Ammeter back up (it wasn't there before) I ran a wire from the lug on front of the alternator to the positive (charge side )of the ammeter and a wire from the negative side to the battery. I also ran a wire from the number two plug on the side of the alternator to the lug on front of it. then I ran a wire from the number one plug on the side to a idiot light then to the ingnition terminal of my key switch. I need to take more pics. I'm pretty much done with it now. Finally !!!!
