D-19 Wheel axle seals
NEKS
Need to replace a rear axle seal on my D-19. Are they still available? I have never moved or removed the wheels on this thing, so may be hard to break loose. Has spin out rims so was no need to. Thanks
I don't think finding a seal will be too hard. You're first step is to procure the three special Gr8 pusher bolts to break the rear wheel wedge collar loose from the axle. I think they are still available from AGCO and are the same pusher bolt for D19-190-190XT-200-7000-D21. Until you have this tooling your seal is going to continue to leak.
