Allis Chalmers 1951 WD
I have a 1951 Allis Chalmers WD. When you throw the hand clutch, the tractor keeps right on going unless you stand on the brakes. When you release the brakes, it takes off again. When you throw the hand clutch, it has decent "snap" but does nothing. Is the hand clutch out of adjustment? And if it is, how do you get to that particular clutch and how do you adjust it. Any info will be greatly appreciated.
To get to the clutch, remove the battery box. Clutch cover is under that. There are brass shims in three locations around the clutch. Loosen (don"t remove) the two bolts that hold each shim pack in place. Sounds like you need to add shims. Should have the same number of shims in each location. Usually when the clutch doesn"t snap clearly, you need to remove shims. Check that the linkages at all three locations are good- pins not worn excessively, throwout bearing yoke not broken. If it is, the tractor needs to be split to replace the yoke. I&T AC-11 is the service manual for that tractor.
Thx a lot. I will report my findings when I get a chance to open it up. It is pretty low on my list of things to do, but I hope to take a look at it this summer.
Thick oil will keep the hand clutch from completely releasing, You can put in 20 weight non
detergent or maybe "tractor lube" that might be thinner. As the oil gets warm from running the
tractor and working or a half hour or more it may get better. You have more of a problem than this,
and probably as has been said need to add shims. The snap into lockup doesn't need to be too strong
not to slip, you may need to experiment.
Is there any way to test or find out what thickness of oil is in it currently? I have no clue when the last time the oil was changed if that would affect it at all.
Hand clutch "creeping" has been a very normal and expected operating quirk of the oil bathed clutch since 1948. Too many people think there's something wrong with the clutch, when in reality, that's just the way it is. Hook the tractor to a load....a plow or disc and when you release the hand clutch, I'll bet it stops just fine. Warm oil makes a huge difference in the clutch not creeping. Get over it. You might wind up looking for the needle-in-the-haystack and there's no needle to be found.
Gear oil, (80-90) has that special smell, one way to tell. While you are think gear oil when was
the last time the final drive gear oil was changed, many seem to forget about these.
I don't know the last time any fluids where changed. I just inherited the tractor from my grandfather a couple of months ago.
Sounds to me like the clutch is rusty and sticking.
My 45 diesel is now retired except for parades. Parades are the
only time I use the hand clutch. The first time I throw the lever
forwards I have to step on the brakes to get the clutch to
release. After that my tractor will not creep forward in the
parade line up unless I'm on uneven ground.
Well, I doubt that you have any Parades that the outdoor temps are below 60 or 70 degrees. If you're brave enough some day, fire up that old diesel on a day when it's 20 degrees outside and tell me how your hand clutch still doesn't creep. I'm just sayin.....temps and oil viscosity make a big difference, as does the 2 disc design (older models) and 3-disc design (later models).
