Rear rim paint code(color)
if you mean the silver rim portion
I believe that the rim was actually zinc coated from factory not painted
but I will defer to others on this as I'm not totally sure
Well it is all in. Oil lines all fixed, fuel pump hole covered. Itching at the bit to fire it up! Waiting on a new battery box and steering wheel. Working my way back. Had hyd leak,pto leak. Hope to drive it out of the shop soon.
That's good! Should be like new when you get done. Did you have to nip a bit off the end of the crankshaft then?
Ross
Ross. No took the welder to the crankshaft pulley, ( cast iron) turned it up real high and burnt the hand crank part of it off. Worked fine, and I don't think I want to hand crank it anyway.
The rear rims were never painted from the factory. They were galvanized. Several people have used Rustoleum Hammered Aluminum paint and say it looks close to the galvanized texture.
