I'll try and make this painless.
1940 WC Tractor destroyed in fire. Eng # on L side of engine starts with WD. ???? Boss wants it redone. All is progressing well.
Engine is on a stand so flywheel is removed. Timing is disturbed since the Mag and mag housing have been removed from engine. Actually mag melted. Since engine has been turned to facilitate pre adjustment of valve lash on refurbished rocker arm shaft. I have read and i have seen much different input on how to static time this thing. If I bring the engine to TDC it appears that there is a marked divit between the cam gear. Does this mean anything? What procedure from beginning to bolt the housing in. At what position should the lug be in before I install the mag? Now where in relation to all of this is the F mark on the flywheel be located? This is the first tractor that I have had the priviladge to work on. Really enjoying it. I am a car and bike and helicopter nut. Now I am wondering why it took me so long to " get with it". Any input would be welcomed. If I can figure out how to post pics I will. Thanks for the help.
