WD p.Steering
cuby
Has anyone ever mounted a p.steering pump{factory} off a D17 series 4 along with a Charlyn Torq.gen. onto a WD?
If so,how did it work?
Pictures?
Would require fitting the entire D17 front supportwhich has the steering shaft on the Left hand side and the WD has the shaft on the right-with enough time and $$$$ it could probably be done. Search for the D17 in the agcopartsbooks.com guest book.
Check that-i see now u just want the pump of a D17 and chrylan drive unit-probably more feasable. Pending D17 and WD block mounting spots for pump.
I was figureing on maybe makeing the P.steering pump{D17 series 4} brackets and a resivor to fit the WD and useing the Charlyn torg motor.
Maybe no feasable.
