Hey fellas, I have been chasing oil leaks down on a ca that I am planning on painting this spring and the front crank seal behind the crankshaft pulley has a consistent drip. The question I have is, does the front axle assembly need to be pulled on this to get the crank pulley off?? My manuals don't have anything about removal but it looks to me like that's the case. I have replaced crank pulley seals before on my wd45's but not the CA. The cast steering sector don't appear to have the clearance needed to remove the crank pulley so I can replace the seal. Any help from you guys that have done this procedure before would be great. Thanks so much, Sincerely, Hoss
