More questions about a WD45 crankshaft
jerkus730
I found a crankshaft for sale that's supposed to be for a 45. You can see someone ground off the last number which is a 5 of the casting
or part number and stamped a 1. So it says 226531 instead of 226535. Does anyone know anything about this?
Get a tape measure. Close one eye, and lay the tape on the center of the #1 con rod journal and eyeball to the center of the #2 rod journal. 4 inches gets you a WC-WD crankshaft. 4 1/2 inches is a WD-45 crank.
If it's the same crank he posted on the other AC site the last digit had been ground and re stamped. If it were ground undersized, it should have been stamped .010, .020 etc and it would be stamped to designate what the rod/mains were ground.
AaronSEIA
AaronSEIA
He sent me a picture of it .
