I poster this on unofficial Allis board and thought someone on here could help.I posted a week or so on the CA I got for my son; The lift went up and won't come down. I put it in the shop this AM and disconected the Line feeding the cylinders. The lift drifted down so I reconnected the hose and started it up. No matter what position the lift lever was in the lift woulod drift up. It would stay down as long as it was held down but if you let it go it would start to drift up. I say drift up because it didn'tcome up as fast as if the lift lever was in the raise position. Also if you let it drift up it wouldn't go back down even with weight on it. I know that it is an internal problem so I took the pump off and started disassembling it' I have an IT manuel but it leaves a lot to be desired as far as instructions go. I found nothing wrong with the pump pistons or ping plugs as the IT manuel calls themsprings and nothing with the speed control . I haven't took the unloader out and checked it yet, I'll do that tommorow.
My question is is there something I'm missing or could the unloader cause the problems I'm experiencing?
