Pulled my 190xt apart for an engine rebuild, actually my son did, got engine back together and everything is good there. The
problem is with the hydraulics. After the pump primes up it blows oil out the fill tube and also out the trans input seal. If it
were an engine I would say it has a blown head gasket. Air is getting pumped into the hydraulic tank and forces the oil out. The
system was completely drained because of water contamination. I have been over the complete system checking for leaks and making
sure everything is plumbed correctly. I think the moisture has caused a valve of some sort to bind up somewhere. To the point if
I had dynamite I would not have a 190. Any ideas what else to check. Holiday so dealer/tech support is closed.
