ASAE deawbar extention ffor AC - B
Ted in NE-OH
Allis Chalmers made a triangular plate to extend the implement hitch point further back from the drawbar. If any one has one I need the maximum length and width dimensions. I also need to know how thick the plate is.
Thanks
If I remember right my C has one on it. I will try to remember to go out and look and see what all I can find as to size etc.
It is made of 3/4" plate. This one does have the extra set of holes but otherwise it appears to be a factory piece. The hitch hole has enough wear I can not be exact as to location. Hope this will help. If you need more info let me know. Lee
I don't thinking drawbar did extend the hitch point back as far as the ASAE drawbar plate did. The critical point was the distance from the hitch point to the end of the PTO shaft. If I remeber correctly that dimension should be 14 inches
Ted,
It appears you are right; the ASAE drawbar seems to extend out further.
The picture shows the required supports.
Interesting how the ASAE drawbar is bolted to the underside rather that the topside of the standard drawbar.
