Can a D-19 do dual hydrolics?
Hi all,
I have a D-19 gas with 3 single hydrolic ports, one lever one port each means they are single anyway it would seem. Ive only ever used the main one for my haybine which is single acting. I bought a baler that needs dual hydrolics for the kicker, my question is is there a way to get dual hydrolic out of what I have? Thanks
Eric
D-19 has dual-acting hydraulics, YES. If you have three levers to the left of the seat, one of them is for the lift arms......the other two are for 2-way hydraulics like operating an all hydraulic loader. On the back of the valve stack, there are plugs to be removed and install your couplers of choice. For the two levers, you'll need four couplers.
Be careful his kid went to unhook the wagon and he thinking to be helpful hit the lever . It could happen to anyone with a thrower but that spring speeded it up a little outside of a little headache the kid was alright
Here's what I have. almost looks like I may be set up already? Looks like 4 places available and the two seem to be on the same lever, does that make sense? Not sure why the two ports are hooked together. Thanks
