Need Some Help AC WF Fender measurement
bobinmi.
I need the opening location along the bottom of a WF fender. I have included a picture of a WC fender, the opening is centered from each end by 20" with a 14 3/4 wide opening by 13" tall. It is my understanding that the WF is off center to the rear. Looking for those measurements to locate opening and height of opening.
Thanks for your help. Bob
Your pic is of an unstyled WC. Are you asking for dimensions of an unstyled WF? Styled vs unstyled are different.
We are looking for unstyled WF. WC fender is for example only. Axle cut out, we think, is not in the center like the WC. Not interested in styled fender unless they are the same offset front to back.
Thanks, Bob.
From the rear most part of the angle iron edge to the opening, it is 14 inches. It looks like the opening is about 12 inches wide. you will notice from my previous pictures that the WF fenders are not straight across the bottom. They angle up in the front.
I am not seeing where you posted the pictures. Tried the http. and got nowhere with that.
Can you post them on here. Thanks, Bob
Sure do need the pictures and measurement.
It is now on top of page ten. Its your first post about WF fenders.
http://i658.photobucket.com/albums/uu301/7doos/Misc/IMG_1271_zpsxryztp7a.jpg
http://i658.photobucket.com/albums/uu301/7doos/Misc/IMG_1272_zpsccth4pjs.jpg
The http link works for me every time. copy and paste it to a new window, it is not active as a link for some reason. Other wise just go to page ten and look at your old post.
Was able to get to you pictures and they look great, just what I needed. As to
measurements, it is best to measure sheet metal only. At the rear of the fender, pull
from axle opening back to the inside of the sheet metal like I did in the picture. Done
this way it makes sure we are work the same. If you use a thin piece of wood or metal
16" to 24" long and straight, place this at top of axle opening and parallel the bottom,
this will give you the height. Done the same way in the front of the axle, measure
towards the rear, will give you width. Same in front, place your piece at the most
forward spot on fender (over belt pulley) and measure down, this will give you the rise
for the angle. Measure towards the rear from the most forward point of the fender will
give you the start of the angle. Can you measure from front to back (up over the top)to
get the over all length. Can't draw a half round line with my photo tools.
This all sounds hard but will go pretty fast once you find something light weight to us
as a straight edge. Like you said, harder when the tire and rim are on.
If you can email me you address I will send a gift card to a restaurant like Ponderosa,
Applebee's or something like that.
Thank you very much for your help
It is probably easier to pull the wheel. I will do that in the next few days. I have Thurs. and Fri. off and will have the time to do it right. Thanks for the drawing on the photos it will sure help me get what you need.
So how has the weather been where your at? Cold and snowy here. I will await your
measurements. Thanks again for doing this.
Bob
I HAVE THE BACK OF THE FENDER TO THE OPENING AS 13 1/4. THE OPENING AS 8" WIDE AND 7" TALL. WAS THIS THE SAME THAT YOU HAVE. DO
YOU THINK YOU COULD GET THE FRONT MEASUREMENTS OF THE ANGLE WITHOUT HAVING TO TAKE THE TIRE OFF OTHERWISE I THINK I CAN GIVE IT
THE GOOD OLD EDUCATED GUESS. WAY TO COLD TO BE PULLING TIRES ON AND OFF TO GET MEASUREMENTS.
BOB
