D-14 doesn't Return To Idle
Part Time Pete
Lately, my D-14 doesn't like to return to idle. When you throttle it back, it will stay up around 1,000 to 1,100 RPM (I'm guessing - no tach), until you put a little load on it. then it comes down and stays down. I'm guessing it's a governor issue - any suggestions?
Thanks
Pete
Check the linkage and make sure it is not binding some place. Also make sure you have no broken or missing springs
