CA axle clutch
4wdtom
Does anyone know how to get the clutch off of the axle in the housing after you get the housing
off the tractor. Don't see any set screw through the brake opening, Is it pressed on? This is for
an ED-40, but the clutches are the same. Anyone who has taken one out and knows how, would really
help to know what I am doing. Thanks, Tom
see if this helps -
<a href="http://s33.photobucket.com/user/Joecdeere/media/temp%20folder/zzzscan0002_zpsykovrwip.jpg.html" target="_blank">
zzzscan0002_zpsykovrwip.jpg" border="0" alt=" photo zzzscan0002_zpsykovrwip.jpg
</a>
<a href="http://s33.photobucket.com/user/Joecdeere/media/temp%20folder/zzzscan0003_zps0b2mf3tj.jpg.html" target="_blank">
zzzscan0003_zps0b2mf3tj.jpg" border="0" alt=" photo zzzscan0003_zps0b2mf3tj.jpg
</a>
Thanks JoeM, that's a lot more information than we had, Will print it out, Thanks again, Tom
Left the hub or brake drum on axle, removed the 6 1/4-20 socket head capscrews that hold the clutch together and have all parts out, inspected. Springs within spec, ordered new clutch lining and stainless steel ball bearings for clutch. Other parts look good. Thanks again. Tom
