Starting a D-15 Restortaion project
Looking to start this project.
Serial Number D152989
Engine Serial number 15412-R.
Going to use NAPA paint. What is the correct colors for this tractor.
Changing out the Combine rear wheels to power sliders. I have everything to get that part started. Going to Sand Blast and wire brush those parts to get them clean.
Hoping this to be a complete end to end restortaion replacing all seals, bearings anything it needs.
I do have the manuals for the tractor as well.
By the serial number you gave it is a D15 II. D15 1960-62 serial numbers 1001-8169 production 7,169 tractors. The D15 II 1963-68 serial numbers 13001-25419 production of 12,419 tractors. They were painted Persian orange no.2 with wheat(cream) wheels.
That serial number isn't for a series 2 model. The series 2 began at s/n 9001 and up with a dry type air filter on gasoline models. Prior to 9001 has an oil bath air cleaner. There are headlight and muffler differences, but they can be changed....the air cleaner pretty much stays however it came from the factory.
All D-15's, regardless of what year built, were Persian Orange #2 with cream wheel centers and cream colored grille screen. This is the newer orange color and isn't the same as a D-14 or WD-45 for example.
You better look at the serial number he gave 152989 falls in D15 II way up in D15 II serial numbers.
