Larry Hardesty
I continue to work on the 1942 Allis Chalmers C. When I went to put the new seal assembly on the timing gear assembly, it would not fit.
However, it could be that remains of the old seal are still on the timing gear assembly. I am not sure. Before I try to press/pound it out and discover I am wrong, I thought I would check on this list. From the manual I have it says, "The front seal is furnished as an assembly and is pressed into timing gear cover until the projection on its out diameter contacts cover." I do not see a projection on the seal assembly I have. I am sure there are folks out there with more experience with this model of tractor than I have. So, I welcome ideas and thoughts. Thanks in advance
