33 mounted corn picker for a WD
KY AC
Found a 33 mounted picker in good shape always stored inside. It has the brackets for a WD. What is the value? Thanks
Probably scrap although that may offend the seller. Guys want IH 234 or JD 237 pickers for the most part but there can be a spot market for something else on occasion. A spot market type situation where you have to compete with another buyer or massage an owner's ego would be 500-600 dollars in my opinion.
If its in great shape $200 tops...we bought ours for $50 20 years ago. Remember though if you want it for picking corn these were built for 60 to 80 bu/acre corn. They dont work real well with modern high population corn, you'll be using the hand clutch a lot to let the picker catch up. The biggest problem we had was that the elevator couldn't handle all the ears dropping into the hopper, they would actually start overflowing onto the ground.
