So the hydraulics are gone as is the hand clutch. 38" tires on the rear. So she has a downward angle. Do I need to run oil in the torque tube, and what type (dipstick)? I notice that transmission oil also runs out the bearing supporting the main shaft from transmission to main shaft in torque tube. So I'm going to assume that the reservoir for gear oil in the torque tube where the hand clutch used to be will fill out of the transmission. So all I need to do there is fill the transmission up. How do the two support bearings in the torque tube get lubricated? I also removed the PTO drive gears in the torque tube.
Thanks for the help
Thanks for the help
