Re:D17 series 4 split
cuby
Does the power directer assy come with the rear section when splitting? I assume that it does since the p.d.control shaft had to be removed. I thought that I should ask the experts first,as I have said before, I have never split one of these tractors.
Thanks a bunch
cuby
The P.D. clutch will stay on the trans input shaft with the rear section. There's a snap ring that you have to remove to get the clutch off the shaft. There is a good you tube video that shows how to properly shim the clutch.
Brian-Thanks.
one other ??
The shaft that the foot clutch pedal rides on,does it press in to the houseing or does it screw in? The parts photo that I have found does not show that very clear.
Thanks
Got it split. Didnt realize that it may be heavy to the rear with the 3 pt arms on it. Was hooked ahead of that. Put a roller jack under hitch and it came apart.
