Coulter bearing for plow
D beatty
I bought a 2-16 snap coupler plow for the WD45. The front coulter bearing or bushing on bad. I have been trying to get off but no luck yet. Loosened nut and taped on it and it doesn't move but put wrench on bolt and it turns ( soaked with penetrating oil).Does anyone out there know where I can get bushing or complete hub (its a grease able hub) .
Take the thru-bolt out and it should drop out of the steel frame..
As I recall, those Coulters just have a Steel center that slips inside the Coulter, then the thru-bolt holds it all together..I don't remember there being an actual "Bearing" in there..
Ron..
Thank BushogPapa I will kept soaked in penetrating oil. I think that steel center maybe rusted to bolt. When I get it out I will put in a new bolt. I will take the lathe and a piece bronze and turn out a new piece to replace the steel center.
