Have a 1943 allis B...12V generator with a condenser. Has a voltage regulator. Not sure if it has a light switch charger or not. I have had the generator rebuilt. But only puts out 10v. I have manually operated the regulator trying to make it charge at a higher V but not luck.
Is the 12V gen original? What should this tractor have for a charging system if not? If its original I may just need a new regulator. Didn't get it checked out. I could use a wiring schematic too if the 12v gen/regulator system is original
Thanks!!!!
Thanks!!!!
